Results 1 to 10 of 17
Thread: What do you wish you would have done?
    North Florida
    Default Re: What do you wish you would have done?
    - Would have brought in a landscape designer right at the get-go, even as the pool was getting planned.
    - Would have specified a contract termination date and added a performance (penalty) clause.
    - Would have researched stonework/rock work to be sure the correct type stone was being used.
    - Would have been more skeptical when the PB said the cleaner return was not a problem to access UNDERNEATH the waterfall. (Try disconnecting that in the winter, if needed.)
    - Would have looked into better pump sizing and efficiency. (Never gave a thought to energy consumption )
    - Would have gone slightly deeper, maybe 6.5' or 7' instead of slightly under 6'.
    - Would have gone with a less slippery deck surface.
    - Installed a heater or heat pump.
    - Installed a control system and/or add a 2nd timer to control the cleaner.
    Wow, I guess we learned a lot with this first pool! It's actually quite nice, but, as you can see, we'd be better-educated consumers the next time around.
    Sandy
    ivyleager is offline Lifetime Member Weir Watcher ivyleager 0
    North Carolina
    Snuck out in '76 to the Led Zepplin concert.
    Had 2 kids instead of 1
    CaryB
    North Carolina
    No seriously:
    -gunite instead of vinyl
    CaryB
    Omaha, Nebraska
    I would have added a 3rd return jet near my steps to help with circulation/cleaning in that area. I also would've gone with the fiber optic lighting instead of the SAM light.
    Jean
    __________________________________________
    20 x 40 33,000 gallon vinyl liner inground, Nebraska
    Ocoee, Florida
    Take the sun tan shelf in the shallow end from 8" to 14" depth
    15,000 gallon IG free form 16x32 w/attached IG 6x7 spa. Aquapure SWG, Jandy Aqualink 4 w/ PDA, Paramount infloor cleaning system, Starite 400K propane heater, Starite system 3 filter, Starite 2hp pump, polaris D'Light LED pool and spa light and paver decking. Completed in 11 weeks 7/4/06.
    I would have made the warranty crew completely redo the liner when they made such an ugly mess of the second liner. Now I'm caught between wanting it to fail so I can get it done nicely, and NOT wanting it to fail because I want to get as many years out of the liner as possible.
    Other things I change as I need to, and mostly have been changed. I see the next changes as improvements, not regrets.
