Thread: winter pool
    Default winter pool
    Ok so ive read all the threads about closing pools for winter most talk about snow and freezing. As i live in Southern cal near Palm springs guess freezing pipes is not a problem . so what do i need to do to look after my pool during the winter. Where do i keep the chem levels ??
    30x15 ig gunite pool de filter 1 skimmer and 3 returns all underground.
    Thanks.
    Cool Re: winter pool
    Borrott, aylad doesn't close her pool there was this thread last year. If that doesn't provide enough info for you, just ask here and I or someone else will be along to answer.
    Default Re: winter pool
    Just keep the chem levels where they normally stay....which won't be hard since as the water gets cooler your chlorine consumption drastically drops. Run the pump overnight when there's a danger of freezing. That's about it!! It's SOOO much easier than having to close and re-open again!
    Smile Re: winter pool
    thanks. will do just that pool is using noticeably less chlorine now and is clean & clear.
    Thanks all.
  1. Leaving Pool Up In Winter
    By joslinm in forum Above-Ground Pool Construction & Repair
    Last Post: 08-22-2012, 02:52 PM
  2. Winter Pool Construction YES or NO
    By captgene in forum In-Ground Pool Construction and Repair
    Last Post: 01-07-2008, 12:44 AM
  3. Take the pool down for winter or leave up?
    By cnk in forum Above-Ground Pool Construction & Repair
    Last Post: 12-01-2006, 07:34 AM
  4. Closing an IG pool for the Winter
    By Poconos in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-18-2006, 11:16 AM
  5. Winter Pool Cover
    By johnnyf0614 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-12-2006, 11:25 AM
