Results 1 to 10 of 10
Thread: do you need to turn off SWG when adding chemicals
    Texas
    Default Re: do you need to turn off SWG when adding chemicals
    Quote Originally Posted by mwsmith2
    I run mine 6 hours a day...that's it. All you really need to do is to turn the water over in the pool twice daily and you're good to go. For instance if you have a 10,000g pool, and your pump can do around 28 gpm, then 6 hours is close enough. (10000/(28*60)=6)
    OK, help me with your math..
    It looks like 6 hours is enough to turn the pool over only once, not twice.
    What am I missing?
    Ontario
    I'd rather use bleach if I had to shock, because it's cheaper in the long run.
    theres no issue with using bleach in a swg pool?
