Thread: cleaning filter grid
    Ohio,Canton
    Question cleaning filter grid
    After closing my pool I soak the DE filter grid in a barrel before storage.I have used a store bought chemical to clean it .I believe muratic acid can be used to clean it and I would like to know the amount needed. I'm sure this has been posted before but I can't find the answer ,Thanks for the help.
    Default Re: cleaning filter grid
    I've never done it because I have a sand filter, but maybe this thread will help...
    http://www.poolforum.com/pf2/showthr...+muriatic+acid
    Ohio,Canton
    Red face Re: cleaning filter grid
    Thanks for the info ,I think I will go with the 1 to 20 ratio with the acid. I have the grid type element . Going to put it in the barrel and let it soak overnight . I really appreciate the reply.l
    When I clean my grids, I use about 1 pint MA in about 3 gal of water. Never thought about what the ratio should be. I let them soak for about 10 minutes and brush them with a soft brush before a thorough rinse. That way, the reassembly is more fresh in my mind. The grids have always come really clean even with the short soaking time.
    Hal
  1. Operating & Cleaning a DE filter
    By packerfan in forum Pool Equipment & Operations
    Last Post: 05-03-2018, 08:54 PM
  2. What the best De Filter for lots of sand, Grid or Cartridges?
    By intrepid in forum Pool Equipment & Operations
    Last Post: 03-11-2012, 04:44 PM
  3. Bc2jones - New User- DE Filter Grid Cleaning Advise
    By bc2jones in forum Pool Equipment & Operations
    Last Post: 04-11-2011, 12:21 PM
  4. Tear in DE Filter grid... temporary repair?
    By JWB in forum Pool Equipment & Operations
    Last Post: 05-25-2009, 07:08 PM
  5. Hayward Pro-Grid or Pentair FNS plus DE filter??
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 04-25-2007, 11:48 AM
