Closed Thread
Thread: Worn coping help
    Default Worn coping help
    hi all, I had some worn spots on the coping from my solid winter cover. Can you paint the worn out spots white to match the rest of the coping ? If you can, what type of paint can you use? If you can not paint do you need to replace the coping ? Thanks
    Ed
    Clueless in NJ
    duraleigh Guest
    Default Re: Worn coping help
    What the coping made from?? Aluminum?
    Quote Originally Posted by duraleigh
    Dave, Sorry- yes it is aluminum and I have a Steel/vinyl IG.
    Ed
    duraleigh Guest
    Hi, Ed,
    Maybe some of the AG experts will be along soon (matt4x4, where are you?) to give you a definitive answer.
    IMHO, it should be fairly straightforward to sand down and paint with a good spray enamel.....like Rustoleum. The issue will be trying to match the existing paint.
    Depending on how picky you are, you may want to repaint the entire coping rather than trying to match the existing.
    Whatever you decide, you should have fairly good success if you use good painting techniques.
    Ed, there may be something special for coping but I'm not aware of it. Let's see what others say.
    Dec 2005
    Athens, Georgia, US.
    I recently painted my aluminum coping on my IG pool with Rustoleum. I decided to paint all of it. Buy a lot of masking tape! Been 8 weeks and it still looks great.
    Bill Marshall
    Quote Originally Posted by rrwcm
    A big thanks to Bill and all who replied . I have a small can of oil based rustoleum(not spray paint) protective enamel-flat white. I hope thats what type of paint to use. I think I will try this next week,so if I have the wrong paint please let me know
    Ed
    We had the same question -- thanks for posting this and thanks all for the replies. Joie
Closed Thread
