Thread: A coworker's swamp
    elsie is offline Registered+ Thread Analyst elsie 0
    Smile A coworker's swamp
    A coworker just bought a HUD house, hasn't closed on it yet. She doesn't know the size. I told her if she would measure the length, width and depth at deep end and shallow end, someone here could tell her approximately how many gallons? I'm assuming at this point it's a vinyl liner. She knows nothing about pools and I told her I would try to mentor her if she uses the BBB method.
    I looked at picture she sent me and the water is swamp-green. I also sent her a post in this forum about a member's pool being transformed in the course of less than a week from green to sparkling blue using bleach (her realtor told her she would have to empty the pool, I told her can't do with a vinyl liner and no need to anyway).
    We can't test for CYA because of the color of the water, and of course can't test the CL either until that water becomes clear, so once we know the gallonage, how in the heck do we know how much bleach to add on a twice daily basis (since she's at work during the day)?
    Thanks for any help with this!
    Smile Re: A coworker's swamp
    elsie, you're a good soul! As I'm sure you realize, bleach (and lots of it) is the way to care for this problem! If it's a total guess as to gallonage and cya level, I'd say to dump 4 gallons of 10 - 12% chlorine 2X a day until you can see the bottom and get an idea of how deep it is. IS the pump and filter system running? Using the filter 24/7 will help clear it up more quickly! However, your friend needs to know how to clean the filter when it starts getting clogged -- we can help
    Try to get the pool to a point that you can measure both the cl and cc levels and also the depth. We can give you a good # for the gallonage
    Scottsdale, Arizona
    Default Re: A coworker's swamp
    Is "gallonage" a word
    Thumbs up Re: A coworker's swamp
    If it wasn't before - it is now
    Yes sirre Phillbo, gallonage is a word (but I'm not sure sirre is):
    Main Entry:
    gal•lon•age
    Pronunciation:
    \ˈga-lə-nij\
    Function:
    noun
    Date:
    circa 1909
    : amount in gallons
    Waste, she doesn't even know the filter type at this point, but if it's a sand filter, I imagine it will just involve a lot of backwashing when 12-15 above baseline psi. If it's anything else I'll come back with questions as I know nothing about other kinds of systems. Thanks for the input re: how much bleach to add. Will report back at some point (could be weeks away).
    Scottsdale, Arizona
    Quote Originally Posted by elsie View Post
    Main Entry:
    gal•lon•age
    Pronunciation:
    \ˈga-lə-nij\
    Function:
    noun
    Date:
    circa 1909
    : amount in gallons
    Well, I guess this place is worth the price of admission, I lernt something new today
