Results 1 to 8 of 8
Thread: Minimum time to filter pool daily?
    Honolulu
    Default Minimum time to filter pool daily?
    Anyone have a recommendation for minimum daily filtration? I have no algae problems (thanks to 9ppm chlorine, which did the trick - thanks, Pool forum!)
    I am wishing to minimize my pump cycle to conserve electricity. Is the rule of thumb to filter each ft2 of water one time daily?
    I have a 21,000 gallon pool and my filter is rated at 96 gpm.
    21,000 gallons, in-ground, saltwater chlorinator, loving life in Hawaii
    Default Re: Minimum time to filter pool daily?
    The rule of thumb that we've always advised is to run the pump long enough to completely turn your water over at least once daily (during the swim season, anyway.....it can be substantially cut down if you leave your pool open during the winter).
    Scottsdale, Arizona
    Also take in to consideration how much chlorine you need to generate.
    Central Texas
    Dunno about the saltwater generator, but I experimented on my 15K gallon pool and got it down to the minimum that keeps it looking okay. I run the pumps twice a day - 2 hours in the morning and 2 hours in the evening. That gets the pool 95% clean in terms of visible stuff like leaves on the bottom. The Polaris may miss a few things now and then, but it usually gets the bottom clean.
    Tom Wood
    15K IG Plaster, Sand Filter, Polaris 180
    Honolulu
    Thanks, I am going to try dropping from 7 hours to 4 and see what happens. At 96 gpm on the filter, it should take just under 4 hours to filter the whole pool.
    Attleboro, MA.
    My pool is only 7500 gallons, not sure the gpm on it but I run it for 3 hours in the morning and almost 4 hours at night, I'm def. going to lower it this summer.
    Nicole: 18' round AG with AstralPool Sand Filter and 1.5hp AstralPool Pump
    Indiana.
    Quote Originally Posted by windfix View Post
    The rating of your filter is its maximum flow rate. The actual flow rate of your system is determined by the pump size and the pool's plumbing.
    Dec 2005
    Jupiter, Fl.
    I run mine 10 hours/day in the summer due to the high water temp here in so. florida. My pool is 90 degrees. It may be overkill but my attitude is better safe than sorry.
    I live in South Florida. I have owned my first pool for 6 years now. 12,200 gal. with exposed aggregate finish, spa with spill over, cartridge filter, pop up bottom cleaning jets, Chlorine by swg. I am eternally grateful for The Pool Forum!!
    15'x30' Rectangle w/ ovals at ends 12.2K gal IG pool; Bleach now as SWCG died.; Hayward 1200 cartridge filter; Emerson 2HP pump; 6hrs; Taylor K-2006 La Motte Borate Test Strips; utility; summer: ; winter: ; iPad; PF:9.8
  1. First time pool owner questions on filter and pop-up floor cleaners
    By bpuck in forum Pool Equipment & Operations
    Last Post: 10-12-2011, 07:41 AM
  2. new intex pool - how many hours should filter run daily?
    By springtunnel in forum Pool Equipment & Operations
    Last Post: 07-19-2011, 11:41 PM
  3. Pool Filter Running Time
    By mikerond in forum Pool Equipment & Operations
    Last Post: 06-07-2011, 01:49 PM
  4. How do I determine the minimum time to run my filter daily?
    By 4KidsSwim in forum Pool Equipment & Operations
    Last Post: 07-05-2006, 02:38 PM
  5. How long to run filter daily?
    By famdog in forum Above-Ground Pool Construction & Repair
    Last Post: 06-06-2006, 02:01 PM
