Results 1 to 10 of 15
Thread: Just opened pool for spring, test result questions
    Default Re: Just opened pool for spring, test result questions
    I have the same problem with my test....it's pretty clear, but maybe a hint of a very very light blue around the bottom of the tester. It is my understanding that this should be really blue. I'm going to had some calcium to try and raise it 50ppm to see if I see this blue that is suppose to show up. If it does, then I'll assume I had 0 calcium......
    conductor500 is offline ** No working email address ** conductor500 0
    ky
    I just opened my pool also and was pleased to see it was crystal clear as well. All I did was add a gallon of bleach when I closed it up for the winter. I do not have a quality test kit yet but the one I do have has my levels as follows (27' AG)
    TC 3
    ph 7.2
    akl 110-120
    cya Out of drops will post back later.
    should my chlorine be higher??
    I was under the impression there would be alot of work to do to my pool when I opened it up in the spring.
    duraleigh Guest
    Hi, Conductor,
    If your CYA tests around 30 or less, 3ppm for Cl is okay. If CYA test higher, I would run my FC level correspondingly higher. (search "best guess" on this forum)
    Please come to my house this weekend. I am replacing a large liner and I want you to get rid of all that spare time you have!!
    Valley Forge, PA, USA.
    Cool Went to verify my test results at the pool store
    The pool store test results were similar to mine except pH and Alk. His test showed pH = 8.0 and Alk = 80. His recommendation was to put over 13 pounds of stuff in the water (pH down and some type of stabilizer) to fix this "problem". I pulled out the test kit as soon as I got home from work yesterday and verified that my pH = 7.2 and Alk = 100 (down slightly). The fact that this guy could give me these bogus recommendations with a straight face really sucks.
    I was skeptical of the advice given on this site when I first got here last year, but it's true. I still have a hard time believing these pool store folks can be so underhanded about something that is such a large investment for most of us.
    Thanks for the advice Dave - sorry no time to help with your liner this weekend.
    And good luck to mizzouguy and conductor.
    duraleigh Guest
    Default Re: Went to verify my test results at the pool store
    Yeah, I was somewhat skeptical at first...as I am of almost everything nowadays. (I know that's not a word ). The "common sense" quotient on this forum is just to dominant to ignore, tho.
    I would like to think the pool store folks are not devious, but sloppy. I think they're careless with their tests and, of course, erring on the side of selling you something works out to their advantage as well.
    ky
    I have looked at a couple differant pool stores and no luck on finding the CYA reagent. I am going to order the kit off this site since I have been attending school here. The one store stopped short of telling me that the CYA was not important (maybe I was just reading too uch into it.) It would seem a "pool store" would have all supplies on hand this time of year. Anyway,since my pool has been exposed for 24 hrs. my ch. is dropping ( istill havent added anything as of yet) Ph stable at 7.2 and alk is still at 120. My next "Q" is I will leaving for 4 weeks and I am going to put the solar cover on untill I get back and wanted to know how much I should raise my Ch. before I leave?
    My wife will be here to keep check on it while I am gone. Since I don't know my CYA levels will this be a problem?
    Hey Dave, about that liner. If you live in Atlanta I will be there for 4 weeks come monday
    Thanks for the schooling guys.
    Tim
    P.S. My pool is a 27' AG. Is that 16,500 gal? Need to know for use of the handy dandy bleach cal.
    ky
    Ok, Just got my CYA from the pool store.
    Here are my readins..
    CL. 3
    Ph 7.4
    alk. 110
    CYA 90
    I found this pool store owner very helpful. She did say my CYA was a little higher than it should be and that the only way to lower it was to drain a little and add more water. But she didn't seem overly concerned about it.
    Dec 2005
    I am also am amazed at the bogus advice given but the POOL GUYS.
    Even "Dumb Luck" seems better
