Results 11 to 12 of 12
Thread: borax in the pool
    jrv331 is offline Registered+ Thread Analyst jrv331 0
    Default Re: borax in the pool
    I really dont follow the threads in the "off season" as my pool is closed. I have a question about this thread though, what is the OP trying to get to 50? Sounds like a lot of Borax.
    John
    "I have followed the borax discussion and have added "slowly" the rate of 1 box per 1000 gallons.
    The goal is 50ppm."
    waterbear's Avatar
    St. Augustine, Fl
    This thread is a good place to start to learn about the advantages of adding borates to your water. Therer are many commercial products such as Supreme, Optimizer, Endure, Maximizer, and Salt Support that add borates to your pool. You can do the same thing with 20 mule team and muriatic acid to achieve the same thing for less money.
    In a nutshell, adding borates to 50 ppm will help stabilize your pH and reduce acid demand, will reduce chlorine demand, has algaestatic properties, improves the 'feel' of the water, and makes the water 'sparkle'. (The last two are subjective but they have been reported over and over again by people who have added the borates.) They are particularly effective if you are using a SWG or clorinate with an unstabilized chlorine source such as bleach.
