Just keep in mind that with Dichlor, for every 1 ppm FC it also adds 0.9 ppm CYA so if you were adding 4 ppm FC per day (which can happen if you are using it every day -- doesn't sound like your case though), then after 3 months that's over 400 ppm CYA. Even half that rate is still very high. That's why I mentioned switching to bleach after a week or two of Dichlor and you are right that pretty much no one in the spa world says to do that. They haven't gotten the word about chlorine and CYA the way that Ben spread the word here at The Pool Forum for pools, but there's nothing special about spas and hot tubs -- CYA has the same affect there as with pools in terms of reducing chlorine's effectiveness.
The main difference is that spas and hot tubs are generally not exposed to UV from sunlight since they are either not in the open or are covered (the exception begin "attached" spas that are really cycled water from pools). So algae is usually not a problem and in theory one could go with lower chlorine levels relative to CYA, BUT the bacteria that causes hot tub itch (Pseudomonas aeruginosa) is more resistant to chlorine than other bacteria so actually may need to have a slightly higher chlorine level than to keep away algae. I came up with the 4 ppm FC at 20 ppm CYA as a conservative number based on one published value of 30-50 for the CT (chlorine concentration in ppm times time in minutes) for this bacteria.
The other main difference is the one I mentioned about lots of organic buildup due to bather load since the water volume is so much smaller than pools. The same bather still sheds the same organics (probably even more in a hot tub due to sweating from the higher temperature), but it's concentrated in a smaller volume of water.
Richard
. In this case, would sodium percarbonate also work as the 'non-chlorine' shock? The reason I ask is because we have a supply of Pro-Team "system support" which is basicly the percarbonate and have some indoor pools/ spas that I TRY to take care of.
-- again, thanks for all the info you've provided!!!!!!!!!!!
