Thread: algae kill in cold water
    Default algae kill in cold water
    I had to leave home for an emergency and was gone 2 weeks and the pool didn't cross my mind. Well the bottom is covered with algae.
    Can I still super-chlorinate to kill it off, the water is about 50 deg. and fall is here.
    Darrell W. -------------------------------------------------------------------
    Man!,this water is cold!
    9,240 Gallon
    15'X 26'above ground
    Using BBB method of chemistry
    Hayward X-Stream 100sq ft cartridge filter
    Hayward 1hp Matrix pump
    Daytona Beach,FL.
    Thumbs up Re: algae kill in cold water
    Darrell, of course you can shock the heck out of it. The bleach will be a little more effective at the lower temp If the filter system has been winterized, you'll want to keep brushing the floor/ walls and the algae will just die and lay there. If the system is still up and running, shock, brush and either vac to waste or just vac. The colder water is going to aid in the process, the algae is slowed down and the chlorine is more efficient. Just be sure to shock to the recommended level and keep it there until the algae is dead.
  1. Cloudy water after algae kill.
    By spongebob55 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-28-2011, 04:02 PM
  2. Will adding borax to 50ppm kill Mustard algae
    By fuelman in forum Dealing with Algae & Slime
    Last Post: 06-04-2008, 12:59 AM
  3. Hard-to-kill algae and SWCG
    By dawndenise in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 09-19-2006, 06:41 PM
  4. does shocking kill algae ?
    By lenhorn in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-31-2006, 09:07 PM
  5. High or Low PH to kill green algae?
    By bait99 in forum Dealing with Algae & Slime
    Last Post: 05-01-2006, 03:36 PM
