Water draining from my Filter when pump is off
I have a Jandy DE filter with a pretty basic backwash valve (push / pull type)
I noticed last Fall that when the pump shuts off (after a cycle) that I can hear lots and lots of water leaving the filter and running into the pool. I have a sight-glass in the return line that I can see the water running through.
When the pump comes on there is a lot of air in the filter that needs to be bled off.
About this same time I started to notice water running out the backwash line when the pump is running.
I'm concluding the two are related, since I don't see any leaks anywhere else, there must be a leak in the backwash valve letting air into the system and partially draining the filter when the pump shuts off.
I've removed the valve, cleaned and lubricated the o-rings, but the problem persists. In fact it's getting worse. When the pump is running there is a lot of water running out the backwash line.
The o-rings look good, but I think that is my next thing to try and replace.
Does this sound like a reasonable thing to do, or am I way off base here?
- Mike
13,500 gal, gunite, white plaster, Aquarite SWG, 2 ft Waterfall and Ledge Bubbler
