"Check System, No Cell Power" Error - Aqualogic PS-8
Srry for the double post, but hoping the get answers soon.
Anyone seen this error message? I called Goldline and they said it is probably the main board.
In Diagnostic mode it shows 0V, 0A in both positive and negative polarity, so something is definitely wrong. I tried cycling the system at the breaker level on the panel thinking there might be a glitch as well as re-seating the cell connector that plugs into the panel. No joy.
Everything else seems to be working.
The warranty only covers 40% of parts, no labor after three years past install. Of course our unit was installed about 3yrs and 1 month ago.......
Before I call someone out I thought I'd check here it see if any of you had experienced something similar and might have a solution so I am prepared when the repair guys get here.
