Re: SWG w/ Hi TDS?
The equivalent of the Taylor K2006 is the Leslie's
Chlorine FAS-DPD Service Test Kit from Lesliepool.com
It uses Taylor reagents and is re-branded for Leslie.
Whatever kit you use must have the FAS-DPD Chlorine test, not the DPD or OTO Chlorine test. Both Taylor and Leslie's sell the individual salt test kit too, again, both made by Taylor and re-branded for Leslie's.
Just alternatives.
Re: SWG w/ Hi TDS?
Just FYI. The cheapest Taylor K-2006 kit found on the web (that I know of) is here. The TF100 kit from tftestkits.com here is equivalently priced per use as it has 36% more volume of reagents, though the kit is different in some ways than the K-2006 kit as shown here.
Richard
