Thread: DE Filter Storage
    Default DE Filter Storage
    As part of winter storage for a DE filter. I wash off the grid with a hose and store it in my shed (inside an empty garabage can). Is this OK?
    Minnesota
    Default Re: DE Filter Storage
    I'm curious to read an answer to your question, so I'm bumping it to the top. I would like whoever answers this to also address the need for removing the grids at all and how often that should happen. Once a year seems like a lot. I was told that if I regularly backwashed and added new DE, I wouldn't have to do it at all. But that has never seemed right either.
    Jennie Menke
    MaryLee is offline Registered+ Thread Analyst MaryLee 0
    Southern New Hampshire
    Here in NH we (actually our pool company) close our pool in early October. They hose down the grids inside the DE filter and store just the grid part in the basement for the winter. Other then the ladder and railings, everything else is left outside. I'm assuming this is done so that there is no freezing & expansion in the grids during the "sub-zero" winter months.
    18 X 40 IG Vinyl
    3 1/2' ft to 8' deep
    Pentair DE Filter
    400K BTU Pentair Minimax heater
    Greetings from NJ- I take the grids in for the winter. In the fall,I hose the grids down one by one. I put the grids back together and keep them in the attic. In springtime I put the grids back into the filter. I keep my pump and heat pump uncovered all winter long. I am thinking about covering the heat pump. I have only had the pool for 4 years so I am still learning(thanks to this forum 0 . Just my 2 cents.
    Ed
    I hose off grids at end of summer, reassemble filter and leave outside. Going on 13th year with same filter and pump.
    Minnesota
    Thanks.
    I did take the top off my filter yesterday and hose off the DE. MAN! It was insane how much gunk there was in there! Clearly, the backwashing was not getting rid of all the DE. My filter was weird though -- it's almost like a spiral of sorts. I don't think it comes apart. So I hosed it off best I could. the manual (that my german shorthair grabbed and ripped to shreds shortly thereafter) stated that after hosing off I should soak in degreaser. I didn't take that step, but probably will at the start of next season. It looked pretty good to me.
    Thanks for info.
    Jennie
  1. Solar Cover storage ideas?
    By knarf#2 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-14-2007, 04:58 PM
  2. Reagent Storage
    By DONNIE in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 01-05-2007, 10:19 AM
  3. Muriatic acid storage
    By mohawk in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 12-23-2006, 08:03 PM
  4. Filter Cartridge storage question
    By GreenLight in forum Pool Equipment & Operations
    Last Post: 05-12-2006, 01:11 PM
