Thread: Cartridge filter cleaner any good?
    Default Cartridge filter cleaner any good?
    Anyone have experience with the Blaster 3000 cartridge filter cleaner. Does it work?
    salinda is offline Lifetime Member Weir Watcher salinda 0
    San Jose, CA
    Default Re: Cartridge filter cleaner any good?
    I am curious about this too. Anyone?
    Salinda
    San Jose, CA
    I finally got one this past September and it is really great. Here is a review I posted elsewhere:
    I was very skeptical about this product. It took me a long time to decide to buy it. I couldn't find many reviews and I just could not imagine that it would work as well as advertised. I have one of the largest (probably the largest residential) Clean & Clear Cartridge Filters available. Although that means that I don't have to clean it as often, the filters are large and heavy. I am not a large person and I dread moving the filters out to the lawn to stand there with a hose for an hour cleaning them, not to mention the waste of water!
    Out of the box, this works. I clean the filters over the lawn because that is the most environmentally sensitive way of doing it. The Blaster worked on the lawn no problem, even in slightly uneven areas. I started it slowly as recommended and it left a "path of clean" behind it as the cartridge rotated. It was so cool, my young daughter begged to help and I ended up leaving the task to her which left me with time to descale the saltwater chlorinator, clean the filter canister, and relube the gasket. Even working alone, I could have done all of that because the thing runs on its own.
    The filters were cleaner in 4 minutes each (2 on each end) than they ever were manually hosing them off.
    THANK YOU!!!
    Salinda
    west1745 is offline Registered+ Thread Analyst west1745 0
    Dec 2005
    Quote Originally Posted by salinda View Post
    THANK YOU!!!
    I agree - just got one after reading your review and what a great product! It does a great job on my cartridge filter - with a lot less water and pain in the back!!
    ____________________
    14K gallon inground pool
    plaster finish
    cartridge filter
    SWG - AquaRite
    Dolphin Diagnostic Robot
