Results 1 to 8 of 8
Thread: Pump-how long to run?
    Default Re: Pump-how long to run?
    Quote Originally Posted by xoroniox
    I live in fort lauderdale and run my pump 6hours/day. I also use my pool year-round BUT i do not have a heater. I believe if you cut the pump back to 8hours/day your pool will still be beautiful and in our weather it will be plenty warm this time of the year with or without the heater. plus when it hits the low/mid 90's and the humidity is high the colder the water the better for me at least!!! good luck hope i helped at least a little bit
    -Arron
    Yes, thanks! I think I will try cutting back...how do you swim all year round without a heater though?
    Long Valley, NJ, USA.
    Question Re: Pump-how long to run?
    My presure at when I just pre-coated the filter is 12. Are you saying that 12 x 2.31 = 27.72 is my head? That seems really low.
    I have a 20x40 pool with 3 home run suction lines (2 skimmers, 1 main drain) of 2 inch pipe....and 2 1 1/2 inch lines for returns with 2 jets on each line (total jets 4).
    Filter is a 1 hp Northstar
    Using that calculation....I'm pumping some MAJOR gpms.....that sound right?
    mas985's Avatar
    Pleasanton, CA
    You must also add the vacuum head to get the total head. You can either measure it with a vacuum gauge or try to calculate it from pipe size and lengths. A guess is 14 feet of head for a total of close to 42ft of head. From the Northstar curve, which I also have, gives you about 112 GPM. Yes a good amount of flow.
    Normally, the pipe size is larger for suction than return are you sure the suction is 2" and the return is 2.5"? Also, how long are the runs.
    Mark
    gwrace1 is offline Registered+ Thread Analyst gwrace1 0
    Dec 2005
    South Central Texas
    I live in South Texas and we swim year round. We use a two speed pump on low speed 12 hours per day. On low speed the 1.5HP pump only pulls 3.8 amps. We run pump at night with an SWG so maintenance is easy and water is crystal clear.
    33' Artesian Echo Canyon Ultra II round with 54" wall 26000 gallon capacity -- 1.5 HP 2 Speed Pump / Pentair 26" Sand Filter with Zeolite filter media
    Aquarite Salt Water Generator -- Complete aluminum deck with fence kit
    Aqualuminator with Fountain -- Solar Pool Lights
    Pool Pictures at the link below
    http://community.webshots.com/album/548241672nKeuyR
    You read my pipe size wrong.
    Suctions are 2 inch....returns are 1 1/2 inch.....(I have two 1 1/2 inch returns with 2 jets on each of the two returns)
    If I do have 112GPM...then heck...my filter may not be big enough....Hayward 4820...I think only rated for 95GPM ...gonna have to check this.
