Re: Pump-how long to run?
You must also add the vacuum head to get the total head. You can either measure it with a vacuum gauge or try to calculate it from pipe size and lengths. A guess is 14 feet of head for a total of close to 42ft of head. From the Northstar curve, which I also have, gives you about 112 GPM. Yes a good amount of flow.
Normally, the pipe size is larger for suction than return are you sure the suction is 2" and the return is 2.5"? Also, how long are the runs.
