Thread: 2 speed pump question
    mohawk is offline Registered+ Thread Analyst mohawk 0
    Minneapolis, MN
    Default 2 speed pump question
    Do all 2 speed pumps run off of 220 voltage? I remember when the electrical was put in that they ran 2 lines, but I don't remember what the voltage was. How would I tell if I have 220 or 115?
    Default Re: 2 speed pump question
    Quote Originally Posted by mohawk View Post
    I don't know of any that run off 115.
    There are several ways to tell if you have 220.
    1) You have a different plug on the pump, a twist lock.
    2) The breaker covers 2 circuits in your breaker box.
    3) Use a voltmeter across the two poles.
    4) There are always a minimum of 3 lines--two live ones, and one common. Either live line to the common is 115v, but across the two live ones is 220-240 volts.
    5) Ask an electrician.
  1. If you run a variable-speed pump at half-speed, does the turnover rate double?
    By famousdavis in forum Pool Equipment & Operations
    Last Post: 07-25-2012, 01:22 PM
  2. 2 Speed Century Pump Motor is now only 1 speed
    By TelexBill in forum In-Ground Pool Construction and Repair
    Last Post: 10-14-2011, 10:40 PM
  3. 2 speed pump. High speed puts sand in pool?
    By mjs31 in forum Pool Equipment & Operations
    Last Post: 08-23-2007, 06:00 PM
  4. Question regarding 2 speed pump for energy savings.
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 04-01-2007, 11:53 PM
  5. Dual Speed Pump Question
    By SLS in forum Pool Equipment & Operations
    Last Post: 04-27-2006, 10:41 PM
