Re: Pool Heaters, maintenance?
Yeah, I had some very mild staining around the step area (fiberglass) last year. I guess that's why it got me thinking.
Besides getting calcium in there this year, I was just wondering if I could take it apart and clean up whatever might be starting - the exchangers aren't cheap and that's IF they're available at all.
Or do you think the calcium could abate the process?
Maybe I could get it apart and cycle some CLR (or equivelant) in there to clean it up? Just brainstorming here. I have the upper shells removed right now and it doesn't appear that it would be too difficult to get to the actual exchanger - just wondering if it will be a waste of time to try and do this.
If corrosion occured, I am not sure that cleaning the heat exchanger will help at all. If scaling occured, then cleaning may help.
Calcium will help stop corrosion, but not reverse it.
Appreciate it Mark, thanks!
Any suggestions for an adequate level of CAl in a vinyl pool? I have a heater and tested my Cal today it was 110ppm on a 1 year old pool.
thanks
