If you have a way to circulate the water now, I would go ahead and get the calcium up. I have no experience with plaster pools, but it seems to me that any amount of time spent with the calcium at a level that causes leaching is too much time.
You can use the pump your wife used to drain the cover to supply the circulation. Get a good flow/ circulation going with the pump and slowly add whichever chem you'd like into the stream and let the pump run for a few hours. You would have to put the pump in the pool, which would neccesitate pulling a portion of the cover back, but then you would have the water flowing so that chem additions could be done![]()
