Re: Can a hole be repaired in a fiberglass pool?
Is pool fiberglass much different that boat fiberglass? I have a fiberglass boat or if you prefer a glass reinforced plastic and it can easily be patched under the waterline with epoxy and fiberglass cloth. The patch will be better than original because epoxy does not absorb water like polyester resin does.
Can the pool be emptied?
