Low chlorine production
I have a Jandy Aquapure 1400 in a three month old plaster pool. Its about 26000 gallons.
PH 7.8
CYA 100
Alk 80
Salt level 3.0
Chlorine 2.5, for now
At first the chlorine generator seemed to work great. I had to keep turning it down, eventually to 25%. After the first month of running it, the chlorine production seemed to drop off. I'm running it for about 10 hours a day. I took the cell out, and it looks clean inside. I hosed it out like the manual says to do, but that didn't seem to do annything. The water has warmed up into the high 80s, but the chlorine seems to drop to zero if I don't add some. I keep bumping the production up. Now its up to 75%. The chlorine level seems to fall anyway. We do have a solar cover on the pool, unless we are using it. Today I tested the water away from a return, and directly in a return with the generator on, and it was hard to see a difference. Should I see a big difference there? Am I missing something? Could there be a problem with the chlorine generator? Theres no error message, and all the indicator lights seem to be working. I just don't know. Thanks for any help.
