Results 11 to 16 of 16
Thread: Ph or Alkalinity...which should i fix first
    Default Re: Ph or Alkalinity...which should i fix first
    Leslie's on-line sells their FAS-DPD Service Test Kit--it's the same as the Taylor 2006
    The least expensive Taylor K-2006 kit I've seen online is here. A kit in a similar spirit of Ben's kit in that it has more logical quantities of reagents and has 36% more volume of tests (so is comparably priced to the K-2006 kit above) is the TF100 from tftestkits.com here. The TF100 has somewhat different contents as described here. They are both excellent kits.
    Richard
    Thanks for the great info...i'll order one this weekend and move a bit closer to understanding what i'm doing...;-0
    Kash....Carrollton, Ga
    21x42 vinyl Lagoon 36,000 gallons
    Hayward 1.5HP Superpump & sand filter
    Aquarite SWG---currently testing with Walmart strips
    steveinaz is offline Lifetime Member Weir Watcher steveinaz 2 stars steveinaz 2 stars
    Southern Arizona
    Quote Originally Posted by JKashJ View Post
    I noticed that there are some who sell those on here...any recommendations?
    Leslie Pool, get the Taylor:
    http://www.lesliespool.com/browse/Ho...400000/I/81329
    Best 64 bucks you'll ever spend.
    Shelf life of kits? I am approaching the second year with the kit I bought from Ben. I would assume that the chemicals do go bad (Especially the dpd powder). Should I dump the whole kit and look at Trouble Free or Leslies? Thanks!
  6. #16
    If you've kept the reagents in a cool, dry area, then you can use them for several seasons. If your dpd powder isn't black and in clumps, it's usually still good, too. I have a bottle of the calcium reagents that is from my original PS233 kit, and they are still measuring accurately, when compared with new reagents.
  1. Alkalinity stuck at 0...after 50 lbs. Alkalinity Increaser
    By heyaim in forum Dealing with Alkalinity and Calcium
    Last Post: 07-22-2012, 07:51 PM
  2. Alkalinity?
    By Tammy J in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-19-2011, 04:56 PM
  3. Alkalinity Low??
    By Brunomax in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-02-2007, 03:23 PM
  4. Total Alkalinity and Adjusted Total Alkalinity
    By cheshamjim in forum Dealing with Alkalinity and Calcium
    Last Post: 06-18-2006, 09:36 PM
  5. Alkalinity FAQ
    By VickieC24 in forum Dealing with Alkalinity and Calcium
    Last Post: 04-04-2006, 11:03 PM
