Thread: Liner pulled loose
    Default Liner pulled loose
    I have a 20 x 40 oval vinyl sport pool. It gets covered with a solid cover in the fall and which stays on until late spring or early summer when opening. The last couple of years after removing the cover I would find the liner has pulled out of its track. Usually 3 or 4 spots less than a foot long on each one, but it does seem to get worse every year. I walked by it today and noticed the cover was way low (2 to 3 feet). We pulled the cover and the liner has pulled out on three corners, the 4th has stairs or it would have to. The water level is down the 2 to 3 feet and there is standing water behind the liner. We just had flooding rains last week and I thought the cover looked high one day after that. Does anyone know what might be causing this and how to prevent it from happening. At this rate next year the whole thing will be popped out. Thanks for any ideas or thoughts/solutions.
    Thumbs up Re: Liner pulled loose
    See if you can find some liner lock -- it's a soft plastic/ vinyl barbed 'wedge' that helps fill the gap in the track that receives the liner bead and keeps downward pressure on the bead so it won't slip out (as easily). Similarly, you could just use a few pennies to keep the bead from slipping out.
    How hard is it to get those corners back in on a warm sunny day? The harder it is to get them back in, the more likely they are to pop back out and therefore more area must be secured with the liner lock or loose change
    Default Re: Liner pulled loose
    It sounds to me like two things are happening. First the water or ice on top of the winter cover is actually pushing water out of the pool. Second ground water is infilrating when the water level has dropped and has lifted the liner. You should probably be ok as long as you put the liner back before adding water.
    To prevent this from happening keep a cover pump on the winter cover and pump water off of it when you see it accumulating.
    Quote Originally Posted by cleancloths View Post
    No ice,, and a pump stays on the cover as long as the temperature is above freezing. It was from the 6 to 7 inchs of rain we got a couple of weeks ago in a short span. I had the pool company come out and put the liner back in and put in the liner lock and also plumb in the french drain ( which they should have done in the first place). Then 4 days after they finished we got another 5 to 6 inchs of rain in 24 hours with 4 of it in one night. It floated the liner up with big bubbles but it stayed locked in the track. I have pumped what looks like at least hundreds if not thousands of gallons of water from under the liner. It is so filthy I can't see the bottom to know if I have it all out but am now running the filter non-stop. Any ideas on how to speed up the cleaning without pumping out the water. I am on well water and that is my last option. Thanks for all the advice.
  1. Just pulled cover off.. green swamp water
    By slade8200 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 07-18-2011, 06:59 PM
  2. Liner pulled out in corner, appears to be no track
    By TRHOD12 in forum In-Ground Pool Construction and Repair
    Last Post: 08-11-2010, 03:44 AM
  3. need help liner has pulled out two sections filling
    By jimmyzshack in forum Above-Ground Pool Construction & Repair
    Last Post: 06-19-2006, 10:45 PM
  4. IG Vinyl liner pulled out of bead for several feet.
    By chuckmason in forum In-Ground Pool Construction and Repair
    Last Post: 06-08-2006, 11:41 AM
  5. Loose Coping
    By sunofthebeach in forum In-Ground Pool Construction and Repair
    Last Post: 04-11-2006, 07:57 PM
