Results 1 to 10 of 13
Thread: Air Leak? (from bad O-rings in Jandy valves)
Threaded View
  1. #10
    cajunfla is offline ** No working email address ** Thread Analyst cajunfla 0
    Jacksonville, Florida, USA.
    Default Re: Air Leak?
    Only if the renters-from-hell used that stuff, or the pool guy they called to rescue them. I use the BBB method myself.
    Replaced the o-rings in the Jandy valve, and it appears all air leaks are gone!!!!!!!! YEE HAW !! Now, lets see if the solar panels are still working and not leaking air or water.
    MUCH THANKS to all !!!!!
    Quote Originally Posted by JohnT View Post
    Any chance that the pool has had a non-chlorine sanitizer used previously? Most people describe the color when chlorine is added to a Baquacil pool as being like Mountain Dew.
