Results 1 to 10 of 12
Thread: How/Where to Install chlorinator
    Birmingham, AL, USA.
    Default How/Where to Install chlorinator
    I know that on this board chlorinators are viewed as bad and I will still primarily use bleach however I would like to ditch my floater that I use and install a chlorinator. However, based on my setup I wasn't sure how/where to install one or if I should just hire it done. I attached a photo. I think where I would need to install one would be right where the two paint drop stains are close to the polaris booster pump. I think that is the return line. However, I don't think I have enough room in the line to install an inline chlorinator. Therefore, do I need an offline chlorinator? Also do I need a backflow valve to prevent fumes from backing up into my heater?
    Any advice appreciated
    Last edited by aylad; 04-19-2008 at 09:01 AM. Reason: Pornography not allowed on this site
    Honesdale PA
    Default Re: How/Where to Install chlorinator
    Inline chlorinators are not bad. You just have to know when to use them. When I need to add CYA I switch to trichlor and throw pucks in mine. Otherwise it just sits empty. The vertical rise on your heater outlet should be enough to keep high level chlorinated water from backing up to the heater. Install the chlorinator as far from the heater as possible. Check valves can be problematic and add additional restriction which you don't want.
    Edit: Don't know if you're used to working with PVC but it's easy and cheap so practice first. Getting a straight cut back there can be a little difficult and a reciprocating saw make it easier.
    So based on my picture where would you suggest I install the chlorinator so that it is also far away from the heater? I'm assuming that an offline chlorinator is really the only choice I have given my space restrictions correct?
    Honesdale PA
    I know nothing about off line chlorinators. I assume they are the injection varietey? Like I said...totally dumb here. Someone else will chime in I'm sure.
    Ft Lauderdale, Fl
    Wink Re: How/Where to Install chlorinator
    Easiest thing to do is to relocate your booster pump suction point closer to the heater (on the vertical line) and put your in-line tab feeder horizontally, before it goes into the ground.
    Even better to put an AutoPilot manifold there...but that's another story.
    Sean Assam
    Thumbs up Re: How/Where to Install chlorinator
    Please note that I am speaking of the Hayward CL-220 off line feeder.
    The off line feeder is the basically the same as the in line model. Before many of our customers started getting SWCG systems, they were included on every pool the company I work for installed, as such, I've 'played' with hundreds of them. To be sure, they have problems (!) - but those are most probably minimized by not having them used as the only chlorine source. There are a lot of little parts that tend to break (the connectors for the hoses) regularly (yearly) and the lid o-ring can sometimes need to be replaced more than once a season On the plus side, they are incredibly easy to install, and if you use it as Al uses his, I doubt that you'll have the problems I've seen They do have a built in backflow preventer (which only occasionally sticks ), so a 'check valve' before it isn't necessary.
    If you decide to go with one, remove the pucks when you're not using the unit - this alone will probably prevent most of the problems I've had to fix. If you have any other questions on what I've said, or want a little info on installation - I'll tell you what I know
