Re: Opening Numbers
I must say, at least this guy didn't try to push me when I said I already had the chemicals I needed at home.
Got another set of numbers from the store today while I was there to pick up some DE:
Free Chlorine: 5.3
CC: .8
pH: 7.1
Alkalinity: 100
Copper: 1.19
CYA: 25
A little dismayed to see the copper actually higher than my original, but then again the original number was taken from water before I started any of the equipment or stirred stuff up. I have seen less fallout from the copper than there was when I opened the pool and it is lessing daily so I just added some more sequestrant and that should take care of that problem. I will hold off on adding more chlorine while that stuff does it's work, even though I show CC. Good to see my alkalinity is up and pH is almost where I need it, I continue to test for that once or twice a day and have been adding Borax a cup at a time as needed.
The heat pump is doing it's job too so the kids may just be in the water by the end of the week.
