Thread: Salt level tester
    Davenj is offline Lifetime Member Thread Analyst Davenj 0
    Jersey Shore
    Default Re: Salt level tester
    I used a drop test kit from Leslie. Used it to check against the Pool pilot. Readings are in 200ppm increments. Salt level doesn't change that much, so I could not justify the paying anymore than a drop test kit. I use Ben's kit for all other tests.
    I have the strips from a local pool store. They are pretty expensive....I think 10 strips for $15.00 or something like that. I used 1 at the beginning of last year and 1 and the beginning of this year and I don't recommend them. It gives you a base line, but they are a little hard to read as they basically get grainier in color as the number goes up.
    I have the aquarite and if you use their chart, you'll get pretty close anyway, just undercut the number so you don't overdue it! (besided the fact that the aquarite will give you a good reading after a good 12 hours or so after adding the salt).
