Results 1 to 10 of 19
Thread: Pool opening on the way!
    Indiana.
    Default Re: Pool opening on the way!
    Then I have a TON of work on the deck as we are ripping up the 20 year old rotting cedar and replacing it with Trex.
    Carl,
    Make sure you get the special screws that reduce the problem of mushrooming with Trex, and practice setting them in a scrap piece. Takes a little fiddling with your drill's torque setting. Better to leave them a little high and finish by hand if you can't get it set exactly right. This will give a much better appearance.
    Thanks! I've been simply using a counter-sink drill first, so it doesn't mushroom.
    If you can - secure the trex from underneath - very classy.
