I know that on this board chlorinators are viewed as bad and I will still primarily use bleach however I would like to ditch my floater that I use and install a chlorinator. However, based on my setup I wasn't sure how/where to install one or if I should just hire it done. I attached a photo. I think where I would need to install one would be right where the two paint drop stains are close to the polaris booster pump. I think that is the return line. However, I don't think I have enough room in the line to install an inline chlorinator. Therefore, do I need an offline chlorinator? Also do I need a backflow valve to prevent fumes from backing up into my heater?
Any advice appreciated
On the plus side, they are incredibly easy to install, and if you use it as Al uses his, I doubt that you'll have the problems I've seen
They do have a built in backflow preventer (which only occasionally sticks
), so a 'check valve' before it isn't necessary.
