Thread: Pool pilot flow sensor cord
    Default Pool pilot flow sensor cord
    We have always had an issue with low flow on our pool pilot. The screen is never clogged. But we end up jiggling all the wires and connections and usually can get the unit to turn on. Tonight we decided to take the trisensor apart to see if there was debris inside. My husband noticed that on the trisensor cord that there are 6 connectors with sleeves in them, one is missing a sleeve. Now when he tried to put the unit back together its not responding. My question is are there suppose to be 6 connectors? And if yes can we purchase a new cord. Is this a warranty item? Any thoughts.
    Ft Lauderdale, Fl
    Default Re: Pool pilot flow sensor cord
    Check in the tri-sensor to make sure you also see 6 pins. If there are 5, there is one broken off in the tri-sensor cord...and may be giving you the low flow condition.
    Yes the tri-sensor cord can be replaced.
    Yes, if the tri-sensor has a broken pin, it can also be replaced, but is not covered under warranty.
    Sean
    Sean Assam
  1. Flow rate sensor?
    By henryb in forum Pool Electronics
    Last Post: 08-31-2013, 03:51 PM
  2. Flow sensor
    By alaskahill in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-22-2012, 02:23 PM
  3. How to calibrate flow sensor?
    By Ronald in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-01-2011, 03:25 PM
  4. Bad flow sensor on chlorinator
    By kelemvor in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 11-09-2010, 08:26 PM
  5. Pool Pilot Total Digital How often to check Tri-Sensor Assembly
    By smallpooldad in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-06-2008, 11:37 AM
