Results 1 to 5 of 5
Thread: Evaporation
    xoroniox is offline Registered+ Thread Analyst xoroniox 0
    South Florida
    Default Evaporation
    I would like to find out how much water i am losing due to evaporation. I know there are alot of factors like surface area,humidity,temp ect. i did a search to find some type of calculation to figure out what the loss should be but came up empty. Does anyone know how to figure this out?
    It may also help with checking for leaks,small cracks and the like. Thanks for any help
    I remember reading something on here about evaporation but it may have been from before the crash because i could not find it.
    -Arron
    mas985's Avatar
    Pleasanton, CA
    Default Re: Evaporation
    It is nearly impossible to accurately calculate the water loss. It is dependent on water temp, air temp and wind. However, it does not seem to be dependent on surface area.
    Have you tired the bucket test? Place a bucket on the first step of the pool and fill to the same water level as the pool. If the pool drops faster than the bucket, you have have a leak somewhere.
    Good luck
    Mark
    South Florida
    I do know about the bucket test thanks though, i had a leak about two weeks ago it helped alot in the process to get the leak plugged.
    I will continue to search and hope i find something. Thanks for your insight
    Indiana.
    I agree with the other posts: This is beyond what you can do manually. Maybe if you had a computer with a weather station and sensors to check pool temperature and sunlight intensity, you might be able to write software to simulate the evaporation. Much too complex a calculation by hand, as it can change from one second to the next.
    mas985's Avatar
    Pleasanton, CA
    If you are really want to do evaporation calcs, here are a few links to start your quest:
    http://www.grow.arizona.edu/Grow--Gr...ResourceId=208
    http://www.thermexcel.com/english/program/pool.htm
    Mark
