Thread: PoolPilot Digital Total Control Temp Sensor Location with Heater
    Dec 2005
    Honolulu, Hawaii.
    Default Re: PoolPilot Digital Total Control Temp Sensor Location with Heater
    Sean,
    My apologies for not being clearer in the question. As we have a heat pump and no spa would not the reading be false if located on the return line - in other words the temperature reading would be too high? If so where should we locate the probe? I hope this makes it clearer and thank you for your quick response.
    Aloha
    And yes it the pool, does get cold at 1000 ft elevation when the trade winds blow at 16 mph to 24 mph, pretty much year round. Except today when we had no wind and vog from the Kilauea volcanoe sitting over Honolulu all day - ala Los Angeles on a smoggy day. Yuck.
    Also we have the SC-60 but only a 1 1/2" line is this ok if we convert the short section of 13" to 14" to 2" and then go back to 1 1/2"?
    Ft Lauderdale, Fl
    The delta T (change in temperature from the inlet to the outlet) from a heat pump is not drastic enough to affect the automatic temperature compensation. It should be about 3-5 degrees. A gas heater would be about 7 - 10 degrees and would affect the temp compensation.
    I would not worry about it with your set up.
    With a gas heater, if you position the manifold at least 4' after the heater outlet, there should be enough dissipation of the heat to not affect the temp compensation that much.
    You're fine going from your 1.5" lines up to 2" then back down.
    Sean Assam
    Dec 2005
    Honolulu, Hawaii.
    Sean,
    Once again thank you for the quick reply.
    This is great news and yes it further away than your figure plus it remixes with the pool's unheated water.
    Have all the equipment and additional equipement tools needed to install. The electrician, as we need to upgrade and relocate the box, says he will be out here Wednesday. Will let you know how it is working after a week.
    Aloha.
