Can't keep my PH down
This is our 4th season with our gunite plaster pool. I have continuing problems fighting a rising PH. When we opened the pool last season, we had problems with calcium scale. Did alot of sanding, but lived with it. PH was fairly stable all season. After opening this year, we decided to acid wash and put all new water into the pool. The new fill water had a low PH. After only a few days, before the filter was even turned on again, the PH had risen off the charts. I have increased the alkalinity and lowered the Ph. The problem is that I have a continuing acid demand to keep the PH in the proper range. My numbers yesterday, before I added acid were:
FC 4.5
PH 8.0
ALK 100
Calcium 220
CYA 0
Did having the plaster acid washed cause this problem? How do I get the PH to stabilize. I don't want to have the scale problems again.
Perplexed pool owner Mary
