Results 1 to 10 of 11
Thread: Solar Sun Rings
    CT
    Default Re: Solar Sun Rings
    Just an update, these do appear to work. It has finally been sunny (we have had a lot of haze) and the water temp has crept up to 86. I do have about 90% coverage thanks to using some pieces of solar cover to provide some more coverage.
    They do lay flat and have not become airborne on a windy day. To store when swimming, I fold them up and hang over the fence. There are no sharp edges.
    CT
    I am getting ready to close my pool and figure I would give my update on the solar rings.
    I think they are a good product. They do work, however in my application I think the traditional solar cover works better. I have gotten tired of the removal and installing each time I use the pool and stuffing parts of an old solar cover to fill in the large areas where the rings do not cover.
    Sadly they will not make a return for the 2009 swimming season. I already bought the solar cover for next season.
    ChuckD is offline Unconfirmed User Weir Watcher ChuckD 0
    Duanesburg, NY
    Hey Jetta,
    Just wanted to thank you for this informal product review. I kind of foresaw the tedium of adding/removing so I stay with my solar cover, but good to hear the report of a braver soul than I.
    Thanks.
    ChuckD
    I have and end of season report as well. I found the rings easier to remove than the regular solar cover. We would just stack them on each other and let them float in the pool . After the swim we would just spread them out again. When removing them from the pool it took a litttle longer than a regular cover but it was easier. So I guess it's a tradeoff.
    They do work but not as well as a solar cover. They were great during the hotter months to keep the temp up. However in the cooler months the cover did a much better job of retaining the heat overnight. No surprises there I guess.
    I will be getting a solar reel next season to make removing the regular solar cover easier. We will also still use the rings in the hotter months too.
    Thanks for the reviews, and especially the follow-up posts. It's nice to hear "the rest of the story"!
