CarlD
Test your water first and get readings on your
FC (free chlorine)
CC (combined chloramines)
TC (Total Chlorine--if you have an OTO kit that's all you'll get but that's enough for now)
pH
T/A (total alkalinity)
CYA (stabilizer/Cyanuric Acid)
You don't need a test for calcium or anything else.
My first goal is to adjust pH. As long as it's 7.1-7.8 you are OK.
If it's low, add Borax. If it's high, add muriatic acid.
Then you want to shock the pool, getting your
chlorine level to at least 10ppm, assuming you have no stabilizer. If you do, then you want to raise it to the shock level indicated in the "best guess table".
Then you'll want to add stabilizer, if you need it. My initial target is 30ppm--it's easy to add more, hard to lower.
Finally, you'll want your Total Alkalinity adjusted--for a vinyl pool anything from 80 to 180ppm is actually OK, unless you have a salt-water chlorinator, then 80-125 is best. Use baking soda to raise it. If it's higher than 180, find the thread on lowering T/A.
So....
Borax/muriatic acid: pH
Bleach :Chlorine
Stabilizer: CYA
Baking soda: T/A.
And that's it.
Testing is the key.
