Results 1 to 9 of 9
Thread: Hose
    jrv331 is offline Registered+ Thread Analyst jrv331 0
    Default Re: Hose
    Carl,
    Thanks, I did look on line before posing but didnt see any thing. I'll do a search for the tiger flex. That sounds like a winner.
    John
    Default Re: Hose
    Any one have experience with this brand?
    http://www.poolsupplies.com/cgi-bin/...=4&zmap=105105
    John
    Default Re: Hose
    John, I don't know the brand, but what's pictured looks like the thinner hoses that I've seen which tend to tear very easily I think you would be doing yourself a favor by spending a little more money and getting the flex PVC like Carl suggested (and as long as I'm spending your money, put unions [A/K/A quick disconnects] on the pipe - it cost's more, but IMO is money well spent FWIW - I prefer a glued connection over a clamp or threaded connection because the glued connections don't have anywhere near the failure rate as the others in my experience.
    I do want to point out that the flex PVC will quickly get 'splotchy' or diseased looking when exposed to the elements and UV - there is nothing wrong with the pipe's integrity but it can look pretty ugly (I'm not sure if it takes spray paint well - I've never tried painting some). Also be sure to properly prime and glue the connections, but this is true with all PVC connections - if you need any tips on going the PVC way - just ask, I think by now I've probably glued ~ mile of PVC together
    Default Re: Hose
    You can use that stuff. But be forewarned that it can spring leaks after a couple of seasons, but it's cheap enough and easy enough to replace. Tigerflex is a permanent solution.
    Default Re: Hose
    I didnt know Tigerflex had so many different types of hose. Which is the best for a pool? Which connectors? I need two 12 ft lenghts.
    Just asking here but Im assuming that having one piece is better than having multiple pieces connected together.
    John
    Default Re: Hose
    What you want is for the hose and fittings to be Schedule 40 PVC. 1 piece is better than joining smaller sections together because every extra joint is just one more place to possibly leak. Whichever hose you end up using, you want to be sure to have it long enough to have a couple of feet resting on the ground so as to prevent undue stress on the connections from the weight and movement of the water passing through it.
    Default Re: Hose
    Which Hose do you recommend for pools, H,J,K series or the Spa series?
    John
