Results 1 to 10 of 11
Thread: Local janitorial supply store - 55 gal drum of 12% for $150
    Default Re: Local janitorial supply store - 55 gal drum of 12% for $150
    Thanks for the info gentlemen.
    Option number 3 -
    Found a 50 pound bag of "Dry Bleach" by franklin technologies for $47.00
    MSDS says:
    *Sodium chloride - > 50%
    *Sodium carbonate - >30%
    *Sodium percarbonate - >10%
    Can anyone interpret this for me?
    MSDS is here:
    http://69.149.235.133/images/1/pdf/P710162MSDS.pdf
    Indiana.
    Quote Originally Posted by fishandfly View Post
    MSDS says:
    What you've found is basically a generic version of Oxi-Clean:
    Sodium Chloride is salt
    Sodium Carbonate is soda ash or pH Up
    Sodium Percarbonate is the active ingredient in Oxi-Clean
    It's sodium percarbonate, an oxygen bleach. One company once sold it for non chlorine shock for commercial pools but no longer does because it was not suitable and created more problems then it solved.. The only company that I know of that is selling sodium percarbonate now for pool use is Proteam which sells it as System Support, a speciality product for quickly clearing very badly fouled pools. (It work, btw, but it's expensive and requires a lot of dry acid be added at the same time to keep the pH from skyrocketing.)
    It is NOT chlorine and is not suitable for santizing a pool.
    Sodium Percarbonate is most well known as the laundry additive, Oxyclean.
    It can be a useful product for converting a biguanide pool (Baqua, SoftSwim, etc.) to chlorine in the initial stages of the conversion.
    Thanks guys, I'll keep searching for carboys.
    Brookline, MA USA
    Option number 3 -
    MSDS says:
    MSDS is here:
    Don't even think about using it!
    Sodium Chloride is your regular table salt.
    Sodium perchlorate releases hydrogen peroxide as the oxidizing agent. There's no "active chlorine" species thereneeded for your pool.
    Sodium carbonate is washing soda and will increase your pH.
    So why is it called "dry bleach"? Because the released hydrogen peroxice does the job of "bleaching", but you don't want that kind of "bleaching".
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP
    38 SF DE filter, 1 HP Hayward Super Pump
    Raypak 350k BTU Natural Gas Heater and solar cover
    8 gal Liquidator with bleach
    Dolphin robotic cleaner
    Taylor k-2006 test kit
    topless is offline Registered+ Thread Analyst topless 0
    Jul 2006
    Wichita, KS
    One more thought about the 55 gallon drum. It's going to weigh about 400lbs.
