Results 1 to 10 of 11
Thread: Successful treatment of "pink algae"
    Brookline, MA USA
    Default Re: Successful treatment of "pink algae"
    Thank you, Evan, for this detailed post. I’ve never seen anything more comprehensive on this topic before. The only thing that you missed are chemical equilibrium and kinetics constants of the reactions involved (just kidding…)
    I inherited this pool from the previous owner of this property, which I bought three years ago.
    BTW, I chose Water_man as my user name for a reason. I spend a LOT of time in the pool, to a degree that I’ve told my friends that I didn’t buy a house with a pool – I bought a pool with a house…
    The pool is 28 years old, and to the best of my knowledge it has never had pink algae, although I’ve been using it in the last three seasons more than the previous owner has ever done for 25 years....
    Since the pool is in New England, it’s open during early June through September.
    I opened the pool on this Friday. Here are the numbers of the water analysis, done by the store’s colorimeter:
    FC 0.22
    TC 0.56
    pH 7.9
    CH 171
    TA 101
    CYA 56
    Cu 0.22
    Fe 0.38
    You may be right about the CYA level and the possible ineffectiveness of my previous superchlorinations. I used to shock with 2 bags of calcium hypo, yielding 10 ppm FC, while "The Table"
    shows that 20 ppm is the desired level.
    My DE filter is a backwash type filter (Anthony Apollo VA 38 – 38 SF area) and I BW it frequently as needed (either when the pressure rises by 8 , or at least once a season.)
    My pool opened as a swamp. Here’s why:
    We had a lot of rain this winter and although I drained my pool upon winterizing about two feet, it got refilled during winter and the winter cover (mesh type) touched the water. I didn’t anticipate the unavoidable results of the combination of leaves and tree debris on top and the contact with my pool water, although the winterizing algaecide should have done its job. Next closing I’ll be smarter – I’ll have the submersed pumps in the pool ready in place, and one I notice the cover submerged I’ll pump out.
    As to the green pool: I already shocked with bleach to a 20 ppm level and now the filter is working its a** off to clear the water. The green is gone. All I have is brown precipitate of dead algae, and bluish looking water with high turbidity. But I’ve done my reading here and elsewhere and I’m not panicky. I wonder if any “filtering aids” should help.
    Last but not the least. I’d like to show my appreciation to the owner of the site and to make a donation.
    Is this is commonly practiced and accepted, or, should it be better to subscribe to the sister site?
    Regards,
    Mike
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP
    38 SF DE filter, 1 HP Hayward Super Pump
    Raypak 350k BTU Natural Gas Heater and solar cover
    8 gal Liquidator with bleach
    Dolphin robotic cleaner
    Taylor k-2006 test kit
    Quote Originally Posted by Water_man View Post
    I save that kind of stuff for the 'china shop' section of the fourm
    mbar's Avatar
    Ashland, PA
    One other thing you can try is a "skimmer sock" It goes in the skimmer and collects the very fine particles. You can find them on the internet, or at some pool stores. You can also cut a pair of pantyhose and tie it off and put it over the skimmer basket. As for donating to this site - you used to be able to, but I don't think you can anymore. There is an owner of the site, but he has been missing from here for a while. The good moderators have kept up the site using all of their knowledge to help We all appreciate them so much Just keep posting and the good people here will help you with any question you have. Welcome to the forum.
    Northeast PA
    Brookline, MA USA
    Quote Originally Posted by mbar View Post
    Skimmer sock : another great idea I learned about in this forum.
    My previous dying pump almost choked on it, but my new pump is unaffetcted. I'm amazed by the amount of fine particles it blocks. Cleaning it every few days by a garden hose is easy and it's worth the smal effort.
    22k Gal gunite IGP
    Carterville,IL
    Will it hurt to close the pool for the season if you haven't fully rid of the "pink" bacterium? I'm trying to shock the crap out of the pool after scrubbing and vacuuming it down, what else can I add to help kill this stuff? I was hoping to close in 3 days?????? Help?
    30' Esther Williams Classic Granite
    Installed july 2006
    If you don't kill all of the "pink" bacterium, it'll still be waiting for you when you reopen in the spring, and likely make your water worse as well because any chlorine you put in to winterize will just be used up fighting the pink stuff. Can you please post a set of current numbers taken with a drop-based kit, so maybe we can help you get it accomplished quicker?
    Jante
