Results 1 to 8 of 8
Thread: Initial DE dosage on green pool startup
    Cool Re: Initial DE dosage on green pool startup
    I'm not going to 'slam' the idea, because I've never heard of it nor tried it. However I have said a couple of times here that undercharging or overcharging a DE filter will eventually lead to trouble. I suppose that they are saying "if you need to backwash every 2 hours, don't waste the $ on putting in the full amount of DE since you're just going to dump it in a couple hours". De is relatively inexpensive (have you filled your car's gas tank lately?) and having a less than full coating of DE on the membranes is asking for trouble, if you get a bunch of algae on the grids/ fingers you'll end up having to break the filter down and at least manually clean them, if not having to chemically soak them to get the performance back up to par.
    I wrote up a "use and care for DE filters" document this past winter, if you ask nice I'll post it here
    Are you currently battling a 'swamp' with a DE filter? if so, which kind and what's the sq. ft.?
    Brookline, MA USA
    Default Re: Initial DE dosage on green pool startup
    Quote Originally Posted by waste View Post
    Thanks, waste, and I'm asking nicely Please repost!
    Tomorrow the pro and I are going to open the pool and I already know by now that I have the swamp. Here's why:
    I live in the NE and we didn't finish cleaning up the leaves last fall because snow started early. During winter it rained and snowed a lot. My mesh type pool cover is now touching the water level (it rose up significantly during winter) and there's a lot of flora on top. It's green above and below.
    This is my third pool opening and my first green pool.
    I already had the pink one last summer and I overcame it so I'm not faint of heart...
    My filter is Anthony Apollo VA 38 with 38 Sq Ft area (I confirmed by measuring to be on the safe side.)
    According to what everybody is saying I need to use about 8 lbs of DE per load, right?
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP
    38 SF DE filter, 1 HP Hayward Super Pump
    Raypak 350k BTU Natural Gas Heater and solar cover
    8 gal Liquidator with bleach
    Dolphin robotic cleaner
    Taylor k-2006 test kit
    Thumbs up Re: Initial DE dosage on green pool startup
    Here is my 'info' on DE filters - I wrote this because the same ?s keep coming up and I got tired of X linking to the various threads I've made which, in sum, make up this document.
    Use and Care For most DE Filters:
    (The units I have a lot of experience with are made by Hayward – so most of this applies specifically to them, but the principals apply to all DE filters)
    1) Basics –
    A DE filter is one which uses diatomaceous earth (~ skeletons or fossils of prehistoric one celled plants) to remove all but the finest material from the water. The DE is a white powder which is mined in various places around the world which was formed by the evaporation of the water that these critters lived in. The DE is kept in the water flow of the filter because it coats the internal grids or fingers which make up the filters internal ‘nest’ allowing dirt and debris to be captured by the microscopic paths created by the coating. Because of the nature of the ‘paths’ through the DE coating, algae – which is the approximate size of the paths – can easily and quickly congest a DE filter, most DE filter owners find this to be the biggest drawback of owning one. The DE must be added to the filter via the skimmer, with the pump running, the amount to add is dependent upon the size of the filter. When adding DE to a filter, most manufacturers recommend mixing the powder with water before pouring it into the skimmer – I have found that adding the powder directly into the skimmer is equally effective, if you have more than 1 suction source operating at the time of addition. (having a second, or third, suction source allows the DE rich water from the skimmer to properly mix with ‘non- DE water’ from the other source(s) to evenly coat the grids).
    However, DE filters, while providing the finest filtration, DO have their downsides! If you do a ‘backwash’ (discussed later) or do a thorough cleaning of the filter, you need to add more DE to it – and, if you add too much or too little, you’ll likely have filter problems! Too much DE will clog the filter and decrease the efficiency of it. Similarly, too little DE will not catch enough ‘dirt, etc” and cause the grids to clog up with the debris, both of which require a manual cleaning of the grids and possibly a chemical cleaning of them. Also, ‘bleeding’ the air out of the unit before adding DE is KEY! – the fresh DE can only coat the parts of the grids that are in water!
    Knowing how much DE you are actually adding to the unit is VERY important! The best way is with a premeasured scoop – they are inexpensive and well worth the $ spent, any place that sells DE should have one available. DO NOT USE a 1lb. scoop or canister that is not specifically for DE (ie. A 1 lb. coffee can only holds ~ ˝ lb. DE) If you have an accurate scale that will allow you to weigh the container first and then the weight of the DE when it’s full, that’s fine -- just be SURE to know ~ how much DE you add when you are adding it!
    2) Types –
    There are 2 different types of DE filters:
    The first uses ‘fingers’ (fabric wrapped hollow tubes, usually 100/ filter) to collect a layer of the DE on. This style is also known as a ‘bump’ filter because the DE can be ‘recharged’ via the use of a handle which moves the whole assembly up and down to expose new pathways in the DE coating without having to replace any DE (I’ll talk about ‘bumping” a filter in a minute.) (There are some ‘grid’ filters which have a handle on the top connected to a plastic plate which operate the same way)
    The newer models have a series of grids to collect the DE and either have a multiport valve or a ‘push/ pull’ valve (of which I will speak very little). These units allow you to ‘backwash’ most of the DE out when the filter needs to be cleaned. (* some localities do not allow wasted DE to be flushed into sewers or even onto your own property – in that case a ‘separator’ would need to be installed on the backwash line).
    3) Start - Up
    The fabric which holds the DE does very little to filter the water! As such, a DE filter needs to have a coating of DE on the grids/ fingers as soon as the pool is started up. Your installer or pool tech should do this for you the first time and give you a complete lesson on operating your pool (called ‘pool school’- it’s a lot of info all at once and it is very understandable that some of the info is forgotten by a pool owner). The amount of DE required by each filter is determined by the size of the filter – there should be a label on the filter identifying the size of the unit and how much DE it requires when completely clean. As said, KNOWING how much DE you are adding is key! Make sure to note what the pressure gauge reads when the unit is clean and freshly coated with the DE!!
    4) Maintenance
    Your filter should run anywhere from 8 psi to 20 psi with fresh DE put in it, depending on your pool and filter system. When the psi rises 8, it’s time to clean the used DE out of it. (when doing any filter work, turn off the pump!)
    Bump filters:
    1) open the air valve on the top of the unit for ~ 5 sec. and close (bumping with the unit full of water will harm the unit!)
    2) Slowly push the handle down and quickly raise it up 4 – 6 times.
    3) Now turn the pump back on and see if the psi went down, if it didn’t drop more than 2 psi, you need to dump the used DE.
    4) (if you need to dump the DE) – Open the drain outlet on the filter after doing steps 1 and 2 and run the pump for 20 seconds. Close the outlet and run the pump for a minute (don’t do this if you have an algae problem! The uncoated parts of the fingers will collect algae too quickly and clog), then repeat the procedure (make sure you open the air relief while the pump is running until water comes out of it)
    5) At this point, you have removed ~ 80% of the old/ used DE so only add 80% of the DE you would use in a new or fully clean filter!!
    Grid filters:
    1) Pretty much the same as bump, except you have a multiport which allows you to backwash the filter when the pressure rises 8 psi.
    2) (always!! Turn off the pump when changing multiport positions!!) Turn the multiport to ‘backwash’ and restart the pump, watch the view-glass or the end of the discharge hose to see when the backwashed water becomes ~ clear. When it is fairly clear, turn the multi to ‘rinse’ for 15 – 20 seconds and then back to ‘backwash’ until the water runs ~ clear again. Repeat the ‘rinse/ backwash’ until the water comes out clear when backwashing, add a short ‘rinse’ and the filter is about as clean as you’ll get it using the ‘backwash’ function.
    3) If the water in the pool is fairly clear, I’ll throw in a 1 min filter cycle and do the ‘backwash/ rinse’ cycle(s) again.
    4) At this point, you have removed ~ 80% of the old/ used DE so only add 80% of the DE you would use in a new or fully clean filter!!
    When bumping/ backwashing doesn’t work:
    Sometimes just ‘dumping’ the old De isn’t enough to get you back to proper filter performance – this can be caused by algae (or some other fine debris clogging the DE), or neglect (you didn’t clean the filter soon enough), or the grids/ fingers getting clogged up.
    At this point, you need to take the filter apart and manually hose them off (it’s a wet process – so be prepared to get ~ soaked). I recommend the manual hosing every year (I like doing it in the fall when the pool is being closed because, then you know the filter is ready for another season)
    If , when manually rinsing the grids, you notice that water is staying in the membrane for more than ~30 seconds, it’s time for a chemical cleaning!
    To chemically clean the grids/ nest:
    1) Have a bucket/ container large enough to hold the entire assembly
    2) #1 Add some TSP (tri-sodium-phosphate) to the water or some electric dishwasher detergent to the water and soak the grids for 3 hours – this will ‘de-grease’ the membranes and is the first step in cleaning them, rinse with hose and get ready for step 3.
    3) Dump the container, refill with water and add muriatic acid to the water so that you have a 10:1 water: acid mixture and soak the grids for another 3 hours, this will clean any calcium off of the grids. Rinse grids again and reinstall them in the filter.
    4) Now, run pump and bleed off the air from the filter and add 100% of the DE the filter calls for.
    I Hope that this is enough for most DE filter owners; if you have any questions, we’ll be here to answer them
    This is the collection of my 'pearls of wisdom' re: DE filters. I can't knowledgeably say that your Anthony filter won't take 8 lbs DE, but for Hayward filters, it's 1 lb/ 8 sq ft of filtration area. I think that 4.75 lbs would be enough for your filter (see above), but as I said - I'm not familiar with your brand of filter. I hope that you can find some useful info in what I wrote
    I live in and work on pools in Ct. I know exactly what you are talking about! If you ever need help with your pool, please post here and I will do all I can to help you
    Good luck with getting your swamp swimable! I, and the other great folks here will help you with almost any problem you may encounter!!!!
    Brookline, MA USA
    Oops. I actually read that the recommended dose is one 1lb coffee can per 5 Sq Ft, not 1 lb of DE per 5 Sq Ft. This means exactly 5.75 lbs of DE for my 38 SF filter as you posted. Perfect.
    This is what I'm gonna do.
    Since we're at it: What do you think about BioGuard’s Sparkle Up filtration aid added to the DE? I suspect it's a waste of money.
    22k Gal gunite IGP
    fog80 is offline Registered+ Thread Analyst fog80 0
    Columbia, Maryland, USA.
    This is going on my refrigerator!
    Brookline, MA USA
    It worked. I cleaned my green pool with heavy shocking, many backwashes and refills with DE up to par, not missing a single pound.
    22k Gal gunite IGP
    Aug 2012
    california
    Very informative post, I have a very old Anthony Pool filter with the circular grids, ( 16 of them if i remember correctly) after cleaning them and putting the de back in, a couple of days later im finding the clean de leaking back into the pool...how is this possible? This has been happening alot lately even before I clean the filters, seems that the tank is emptying back into the pool. Once when i used the leaf vacuum, which uses a separate motor and started it up a massive cloud of dirt came out from the drain in the deep end, almost like it is clogged somewhere in the pipes...any advice would be appreciated.
