Results 1 to 10 of 20
Thread: Pool problems.
Threaded View
  1. #3
    localfinesse is offline ** No working email address ** localfinesse 0
    Riverside, CA
    Default Re: Pool problems.
    Quote Originally Posted by JohnT
    That should have raised your chlorine by 15ppm or so. ETA: you said large bottles-do you mean gallons, or the big jugs?
    Yes it was 6 gallons. I don't know why I said 6 large bottles.
    I'd be more concerned about why the water isn't clearing up. Have you cleaned the cartridge, and how does the clean pressure now compare to what it was when new? Cartridges can get dirty or get a hole in them, both of which will make the filter ineffective for different reasons.
    I cleaned the cartridges 3 months ago. I will have a look at them on Sunday. I am having lasik today. (Friday) I will need a few days to rest. I will report back then. Today it isn't green any more just really cloudy. I can only see the 3rd step.
    You do need to lower your CYA, and the only way to do that is water replacement. However, if you replace water, you also have to replace chlorine in order to keep algae under control.
    So how much water should I drain? And do I add more bleach when it is drained?
    I don't really think your TA is over 700. Did you use the 0007 neutralizer? My fill water is insanely high at 400ppm TA. I don't think 700 ppm water would be drinkable. I wouldn't mess with it until you get the other stuff cleared up. If you replace water for CYA, it may undo whatever alkalinity changes you make. Leaving the waterfall on should raise your pH without raising your alkalinity, which is good, but you'll need to keep an eye on your pH.
    What is 0007 neutralizer and where do I get it? I ready a few posts saying if you CL is too high it may bleach out your other results. Do you think this could be the case? I tested the water again today and I had the same results. My CL was orange.
