Results 1 to 8 of 8
Thread: 3/4" pipe?
    mas985's Avatar
    Pleasanton, CA
    Default Re: 3/4" pipe?
    Could it be an overflow line? It would seem to be a bit low for an overflow line. Is your normal pool level different than it use to be?
    Mark
    Jul 2006
    With the pool already being lower than the skimmer I don't think it could be an overflow.
    mas985's Avatar
    Pleasanton, CA
    Then the other option could be a fill line.
    Mark
