Thread: Before I order is this the right Kit.
    Jul 2006
    Default Before I order is this the right Kit.
    Default Re: Before I order is this the right Kit.
    It's the K-2006 by Taylor.
    Yes, that's one of the "Right" kits. Good price, too.
    Honesdale PA
    Yes....right kit. You may also want to get extra CYA reagent R-0013, a pint or a quart as you use 7 ml per test, and Calcium Buffer R-0010. You use 20 drops of the calcium buffer per test. Those are the two you will go through pretty quick.
    Jul 2006
    Cyan Acid - 16 OZ
    #R-0013E 5.90 1 Unit 5.90
    Taylor K 2006 Complete Kit 49.00 1 Unit 49.00
    Cal. Buffer - 2 OZ
    #R-0010C 4.00 1 Unit 4.00
    Ordered,
    thanks-
