Re: Pump Replacement
No, it's not hard. There are a couple of things that can be replaced on the motor. The starting capacitor is a cheap, easy fix. Usually the motor will hum or buzz but won't spin if the capacitor is bad. There is also a thermal protection device that will trip after the motor runs a while that can fail as well.
John
Thanks for the encouragement. Needed a new pump and replaced it with a 3/4 hp Hayward. All is well.
Scott
