Thread: changing skimmer / manufactures
    Default changing skimmer / manufactures
    I need to replace my skimmer, the complete assembly.
    The one that came with the pool is a Waterway Plastics model and I can't find a replacment. My problem is; I would like to replace it with a solid name brand "Hayward" but none of the ones I have looked at have the same cut-out dimentions or number of mounting holes what do I do?
    Darrell W. -------------------------------------------------------------------
    Man!,this water is cold!
    9,240 Gallon
    15'X 26'above ground
    Using BBB method of chemistry
    Hayward X-Stream 100sq ft cartridge filter
    Hayward 1hp Matrix pump
    Daytona Beach,FL.
    Default Re: changing skimmer / manufactures
    Waterway is actually a very reputable brand for skimmers.. I wouldn't hesitate to buy another one...
    your other option is to buy a skimmer with a bigger opening and enlarge your opening/redrill the screw holes.
    A skimmer with the same size opening but different hole pattern "should" be ok, because the gaskets used will create a watertight seal, but if you're not comfortable with that idea, don't do it.
