Thread: Hard Pipe my pump and solar heater
    Cleveland, OH
    Default Hard Pipe my pump and solar heater
    This year I want to hard pipe my pump and solar heater. What kind of pipe should I use? I am thinking a 2" PVC but do I have to go schedule 80 or will standard pvc do the trick? Also should I use any special connectors to make things easier to take apart in the fall?
    Honesdale PA
    Default Re: Hard Pipe my pump and solar heater
    No need for Sched-80. 40 is just fine and a lot cheaper. If you use quick disconnect uions they are probably sched-80. May consider short sections of auto radiator hose right on the PVC pipe. You can get straight 3' sections at almost any auto store and cut as needed. Go with the cheap stuff. Some hoses can run $40 a section but there are cheaper ones that aren't reinforced as much and work just fine. I have a pic in this thread where I used it on the pump outlet line. Same hose in 7th or 8th season now and no signs of deterioration.
    http://www.poolforum.com/pf2/showthread.php?t=7054
    Hose would allow some flexing and if used on the pump it cuts down on conducted noise.
    Quote Originally Posted by MaxxFusion View Post
    Schedule 40 is sufficient. I use a lot of 1 1/2 hard and TigerFlex. I have a 1hp full-rated Superpump.
    Poughquag, New York, USA.
    Remember that not all white PVC is schedule 40, especially fittings and couplings. In the part of NY where I live, Home Depot carries a lot of non-rated fittings. Lowe's has Sched 40 fittings.
