Thread: Just opened pool my numbers...
    Jul 2006
    Default Re: Just opened pool my numbers...
    This is correct, but I would go stronger--stop using the Tri-Chlor pucks. They raise CYA which now is good, and lower pH, which is now too low. Bleach/Liquid Chlorine doesn't change pH, CYA, or Calcium levels, which is why we prefer it to all dry chlorines.
    This is incorrect. Please read the various sticky'ed threads we've generated over the last several years.
    Baking soda will raise your T/A, but not your pH.
    You should use WASHING soda to raise both your pH and T/A. Arm & Hammer makes this in the YELLOW (not orange) box and it should be next to the Borax in the laundry section of the supermarket.
    Washing soda is chemically the same as Soda Ash or the "pH Up!" type products sold in pool stores, only it's cheap as dirt.
    BUT, personally, I would suggest using Borax as your FIRST choice. T/A of 80 is an OK level (at the bottom of the recommended levels) but when you raise pH from 6.8 to, say, 7.4, your T/A will rise as well, maybe to 90 or 100--you have to test it. If it's there after you raise pH, DON'T MESS WITH IT!
    Thank you for clarifying this...re-reading my post, I can where I was less than clear. I did not mean to imply that baking soda raised pH...but that borax and baking soda could be used in sequence...after re-testing, of course
    I personally do not use soda ash often because it is one more chemical...and I am trying to keep things simple...
    Thank you for the clarification.
    25,000 IG vinyl Utopia pool
    Quote Originally Posted by adesalvo View Post
    Not a problem.
    I buy A&H Washing Soda because it's cheaper than Borax and cheaper than both Borax and Baking soda combined (it's AMAZING how the pool chem companies repackage this stuff and sell it for many times more!).
    Besides, you can always use both Washing Soda and Borax as laundry boosters.
