Thread: Does Size Matter with a SWG?
    Default Does Size Matter with a SWG?
    I have an AG Dough Boy, 16x32 with deep end to 6 feet with approx 14,000 gallons. Looking into an Autopilot Pool Pilot Digital Salt Chlorine Generator DIG220 - Complete System with either:
    DIG36 - Up to 20,000 gallons
    DIG48 - Up to 40,000 gallons
    DIG60 - Up to 50,000 gallons
    The prices for each are about $100 apart. I'm gussing that if I get an oversized SWG, say the DIG48, I would be able to run the SWG at a lower level or for less time, saving wear and tear on the SWG Cell.
    Is this true? Are there any other considerations, positive / negative in selecting an oversized SWG for a smaller pool?
    Thanks - Bob
    Last edited by 16X32AG_Bob; 05-22-2008 at 09:50 PM. Reason: Cost difference was wrong.
    Default Re: Does Size Matter with a SWG?
    It's always a good idea to ovesize the cell if you can. If it were my pool I woudl go with the sc48 cell. You are right in that it will allow a lower output percentage or shorter pump run time and that will translate into longer cell life in most cases.
