Thread: Just opened my pool and the water is green
    Cleveland, OH
    Default Just opened my pool and the water is green
    What would be the best way to clear this up? I have a 24' AG. Do I just skip the starter kit and add 2 bottles of bleach a day with the pump continuously running?
    Frank
    Default Re: Just opened my pool and the water is green
    Two bottles of bleach may or may not be enough. You need to test and keep the CL level very high. I think 25ppm is recommended. That may require as much as two bottles of bleach a day. Brush the pool at least once a day and run the filter continuously. The water color will change fairly quickly but it will take another day or two of bleach and brushing before all the algae is dead and gone. You'll know it's dead when your CL test levels stop falling. Then you just need patience while the filter works to get it all out. Good luck, I hope this helps!
    Hal
    Hal has given you some good information about running your filter 24/7 while trying to clear your pool, brushing and having some patience. What we really need to be able to help is a complete set of current water testing results taken with a drops-based kit, not test strips. Repost with that info and we'll help you get this cleared up.
